- Mute
- Permalink
- Report
rest machining doesn´t work properly
after last update rest machining doesn´t work properly. Before I was using it regularly and it worked well. Now fusion cannot compute toolpath if rest machining is checked. I am including pictures of toolpath before and after update.after
before
I have no idea how to fix it. I checked all parameters several times and everything is same as before update so there is no reason why the toolpath cannot be calculated.
- Mute
- Permalink
- Report
Hello and welcome to the forums!
Could you export and share your .f3d file so we can provide better assistance? To do that:
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply.
If the file contains linked component, the links must be broken. If the file cannot be shared due to privacy concerns, you will have to email the file or PM me the A360 link
There are some 3D Pocket bugs currently being investigated, this will give us another test case to look at
Seth Madore
Fusion
