Marco.Takx
in reply to: jaw6667
Hi @jaw6667,
You can use a Trace (On the Passes tab be sure compensation is set to center and multiple depths) or use 2D Contour (On the Passes tab be sure compensation is set to OFF and multiple depths) and use Alt and select one edge like below.
you can make a tangend extensions.
Create a Linear Pattern.
Select the whole pattern and make a new pattern but now a circular pattern 90 deg and select the center of the part as rotation axis.
I’m not behind my laptop so I hope these steps help you.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
