johnswetz1982
in reply to: jaw6667
Use one sketch line vertically and one sketch line horizontally. Use that sketch line in a 2D Contour or a Trace operation with multiple depths. Once you have that one line programmed as you like put that operation into a linear pattern with the offset you want to get your desired final output.
