jaw6667
2650 Views, 6 Replies
V Groove cuts
new to Fusion and have been struggeling to create toolpaths for this trivet I'm trying to make.  Trivet will have v-grooves cut in it spaced evenly and running in the X and Y directions.  I plan to use a V router bit and my router will probably need 3-5 passes to cut it.  I have tried multiple milling configurations but cant seem to come up with a toolpath that will run the length of the part then step to the next pass.
Marco.Takx
in reply to: jaw6667
Hi @jaw6667,
Can you share your model so one of us can take a look at it?
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
jaw6667
in reply to: Marco.Takx
Below is a screen shot of the model. I have it set up as a public share link https://a360.co/2TtV0s0  Thanks!fusiontrivet.png
johnswetz1982
Use one sketch line vertically and one sketch line horizontally. Use that sketch line in a 2D Contour or a Trace operation with multiple depths. Once you have that one line programmed as you like put that operation into a linear pattern with the offset you want to get your desired final output.
Marco.Takx
Hi @jaw6667,
You can use a Trace (On the Passes tab be sure compensation is set to center and multiple depths) or use 2D Contour (On the Passes tab be sure compensation is set to OFF and multiple depths) and use Alt and select one edge like below.
you can make a tangend extensions.
Create a Linear Pattern.
Select the whole pattern and make a new pattern but now a circular pattern 90 deg and select the center of the part as rotation axis.
I’m not behind my laptop so I hope these steps help you.
Marco Takx
Chetan.Bankar
Hi @jaw6667,
@Marco.Takx is right, you can select the bottom of the texture (Using ALT key) and then create a trace toolpath for it. Once you generate two toolpaths one for horizontal and one for vertical line, you can then liner pattern these toolpaths.
Once done you can then use a 2D countour toolpath to profile it around your model with the same tool.
Please have a look at the attached modified project.
I hope this helps.
Chetan Bankar
Global Product Support
Submitting & Viewing Support Requests | Web Support | Phone Support
Marco.Takx
Hi @jaw6667,
I've created a sample see attachment.
Hopefully, this helps you with your challenge.
Marco Takx
