02-19-2019
10:17 AM
- Mute
- Permalink
- Report
02-19-2019
10:17 AM
Wrap toolpath incorrectly cuts wall
Hi everyone,
So I am attempting to cut a wrapped pocket and not having much luck with the wrap option for 2D contour or using 4 axis swarf.
I've attached the file to make things easier to look at.
I assume wrap will not be able to get the correct toolpath because it does not allow for Y-axis output. However, I am running into issues with swarf as well. Even though I have checked the 4th axis limit box in the operation, it still fails to post with the error that it is trying to command additional rotary axii (5 axis toolpath still).
I am using a DMG MORI NLX for this part and should note I have successfully posted 4 axis swarf operations in the past with fusion's NLX post.
Fusion
