mamassey
in reply to: seth.madore
Posted g-code file works fine, but when Fusion 360 creates the file, its creates the file with restrictive permissions.  If I get info on the file on macOS, the following permissions are what the file is created with:
No access for everyoneNo access for everyone
As you can see, I can read and write the file, but no one else can.  This is easily changed, but posted g-code is created from the computer in the office and saved to a network drive.  If I don't change the permissions when new machine code is created, then no one else can open it.
I shouldn't have to alter the permissions. It should be created with less restrictive permissions.
