seth.madore
in reply to: mamassey
What is your machine and controller, and are you using the correct post processor for this? I don't think I've heard of this problem before, so I would certainly welcome more information.
Is it that you are not able to execute the g-code file? Does it come out in a format that should be able to be read?
All the post processor does is basically produce a text document that you then feed into a machine. Unless you have something odd going on, this shouldn't be an issue.
Seth Madore
