01-29-2019
09:16 PM
- Mute
- Permalink
- Report
01-29-2019
09:16 PM
Doing a ramp in quite often works.
Having extra material on the bit of wood being cut so you cut between the bits of wood this give something for the wood to push against when you are cutting.
If it is really bad you use a sketch so you can take the corners of cutting with the grain.
90% of this is user experience it is easy to say what the problem is but how to fix it is hard it is down to the bit of wood. sometimes I have had to chuck back in the stack a bit of wood because it has started to move all by itself some stuff has taken years to stop moving.
There is a lot to it unless you get stabilized wood that is very expensive and very easy to work with.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Fusion
