HughesTooling
in reply to: j.cavender
Did you modify the post for spiral moves?
I've done this mod in my posts but it's not done correctly in yours as there should be a tolerance test. This should be the first test in onCircular and you have the maximumCircularRadiiDifference and Spiraltolerance variables but the code below is missing.
  if (isSpiral()) {
    var startRadius = getCircularStartRadius();
    var endRadius = getCircularRadius();
    var dr = Math.abs(endRadius - startRadius);
    if (dr > maximumCircularRadiiDifference) { // maximum limit
      linearize(Spiraltolerance); // or alternatively use other G-codes for spiral motion
      return;
Your onCircular should look like this.
Mark
Mark Hughes
Owner, Hughes Tooling
