prettygoodnotbad
in reply to: jodom4
@jodom4 Ok thanks for the advice I was experimenting a bit with that at the beginning and had decided early on that conventional milling was a better option, but probably for no good reason, I will try switching back to climb milling.
@Marco.Takx  the tool I am using is this one: https://shop.carbide3d.com/collections/cutters/products/201-25-end-mill-cutter-qty-2?variant=1256409...
It is 3 flute 0.25in flat end mill. I don't know what pitch refers to though, and it isn't indicated on the site.
