seth.madore
So i'm still finding my bearings with Turning (I don't have a lathe in my shop), so this may not be the OPTIMUM solutions, and I'm certainly open to seeing other methods of accomplishing this task.
In the Mill environment of Fusion, I often ask "can I do this in one toolpath". And the answer is often "yes". But (and there's always a but) can it also be done a lot quicker and easier by breaking it up into a couple extra toolpaths? And the answer is almost always a resounding "yes". So, I'm going to do the same with Turning. I duplicated your toolpath and then just applied a few different parameters to it. Give it a look and see what you think of the path. Personally speaking, I'm not too keen on it bouncing between front and back and back and forth. I'll play with it some more to see if I can resolve that. It seems to me the toolpath needs an "order by area" option like Adaptive has
File is attached.
Seth Madore
