Marco.Takx
in reply to: sumness
Hi @sumness,
If I understand you correct you will cut off the part with the Y axis. Or only compensate the With Y axis.
This is something that has to be build in into the post processor. Within the software there isn’t a option (yet).
HSM post adjustments needed? Find your right contact here.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
