- Mute
- Permalink
- Report
I am having issues with the second op on a lathe part today. The profile operation is blowing right through a shoulder like it's not model aware. Typically when the profile function is misbehaving it is because I forgot to tick the spun profile box but that is not the case here. Any suggestions?
- Mute
- Permalink
- Report
Could you share the file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
- Mute
- Permalink
- Report
F3D attached...
See Setup2. Setup 3 was an attempt at a work around.
- Mute
- Permalink
- Report
Set your X axis along this line:
It's certainly being finicky...file attached
Seth Madore
- Mute
- Permalink
- Report
I also noted this issue in your attached file. It's starting the profile at the through hole.
- Mute
- Permalink
- Report
Bugger. So it is. Houston, we have a problem...
Seth Madore
- Mute
- Permalink
- Report
Pointing the X axis at this corner point seems to work,
Mark
Mark Hughes
Owner, Hughes Tooling
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Hey guys,
I managed to replicate this issue. It seems to be a problem with our spun profile algorithm. We're currently trying to replace it with a better algorithm. I will let you know when I have an update.
Akash Kamoolkar
Akash Kamoolkar
Software Development Manager
- Mute
- Permalink
- Report
Great to hear!
Seth Madore
Fusion
