in reply to: Boopathi_Sivakumar
Thanks a lot, but I think it is not the real solution for this issue. I also found a solution like this, I mean this operation was made by "create derived operation". If I make this operation from scratch it will work fine.
But I hope someone from Autodesk should check what is the problem, because someone can have a really bad accident on a milling machine. Fortunately I was near the machine and stopped it immediately. I broke only an end mill.
