HughesTooling
in reply to: Vohnsen
OK the problem is the chamfer around the part is making an undercut if you reduce it to 0.25mm it works. At the momment the outer profile is broken by the bosses and that's confusing the 2d op. I've attached an updated file, to import use Design from file.
One more tip always select the part you're machining in the setup under model.
Mark.
Mark Hughes
Owner, Hughes Tooling
