217 Views, 1 Reply
Trouble with stepped part machining
Good day team
In the Fusion ultimate the 3D model of cavity part has a smooth finish.
Once the part is milled it has a stepped finish.I noticed that when we cut the same part from a Solid Works model
the finishing is smooth.
I also noted that the SAT file type used for machining is only 157 Kb in size
and the SW file is 437 Kb in size
Please can you assist us in sorting this matter as soon as possible ?
