- Mute
- Permalink
- Report
G114 Polar Interpolation
Hi All,
I've been using Fusion to write programs for our mill turn lathe with C axis control and so far everything's been going great. I've been trying to write a program for the part shown below and have managed to get a program that functions and produces an acceptable part but I have some concerns about it. When using the C axis and X axis of the machine together to produce the triangular profile at the back, the C axis performs a lot of stop-start actions instead of smoothly moving around the profile.
We've machined this part previously with a program written in some different software that uses a G114 cycle and produces a smooth path around the part a much shorter amount of code. Is there an option I'm missing in fusion that will produced a path using G114 or a smoother path at least. I've attached the f3d, the segment of code for the triangle area and also a copy of the post we're using right now, any help on this issue would be greatly appreciated!
Fusion
