There's many issues here at a quick glance:
  1. An M10x1.5 thread should have a major diameter of 9.735-9.969 mm - You've drawn it right at 10 mm.
  2. Your OAL of the insert needs to be 16.51 mm, also the pitch needs to be 1.5 mm in the insert definition.
  3. Your thread depth in the cycle is set to 0.92 mm, the thread height of an M10x1.5 thread is 0.812.
  4. M10x1.5 thread should be made in 4 cuts, 15 is a waste of time.
