HughesTooling
in reply to: TOwens777
For what you're doing you don't want to select the model in the op at all. The only time you'd select the model in the op is if you have holes in the part you don't want to machine, then you make patches to cover the holes and select just the patches and include setup model. What you are doing then is adding surfaces to the setup model to fill\cover the holes just for that op.
For the part you're doing now I'd make a boundary curve, you might have to make a sketch in the model workspace if you can't pick a boundary from the body.
Mark
Mark Hughes
Owner, Hughes Tooling
