11-17-2015
08:35 AM
- Mute
- Permalink
- Report
11-17-2015
08:35 AM
Mark, I'm not sure if I'm following you. I have my model selected in the setup.
In this case it's called 'Back - Outside." I'm then selecting Back Outside and using the drop down menu to select my operation
If I select "Include Setup Model" it creates a tool path for the entire model. What if I want to use a different tool on the cutaway portion of the back? I was under the impresssion I could just select the faces I wanted to cut? So, are you saying to do the reverse? Select "Include Setup Model" and then select only the faces you want to cut and choose "Touch Surface?"
I tried that and I still get the same result. It ignores that same small area.
Fusion
