- Mute
- Permalink
- Report
You should be selecting the whole model you want to machine in the setup whether that's a single body or more. The model on the op where you've selected faces is meant for selecting patches to cover holes for just that op not for selecting just what you want to machine. You might get what you're after by going back to the setup selecting the model then unselect the 4 face in that op then reselect them under the Avoid\Touch surfaces section. Or you could try selecting a boundary around the surfaces.
So in setup select everything under Model. Why this is not at the top of the dialog I don't know as it's the most important selection.
Select a boundary, click the boundary curve again and you get an option to change the path.
Here I clicked one of the boundary lines and now have the option to change the boundary.
Or use touch surfaces.
Mark
Edit I would recommend using a boundary as you have more options for how the tool is confined like inside, centre or outside.
Mark Hughes
Owner, Hughes Tooling
Fusion
