- Mute
- Permalink
- Report
Hello World...
so here I go...
I used the original post found in the installed folder, tried to post and got an error, found this post online, and changed this part
// Start of onRewindMachine logic
/***** Be sure to add 'safeRetractDistance' to post properties. *****/
var performRewinds = true; // enables the onRewindMachine logic
var safeRetractFeed = (unit == IN) ? 20 : 500;
var safePlungeFeed = (unit == IN) ? 10 : 250;
var stockAllowance = (unit == IN) ? 0.1 : 2.5;
now its true. OK so I get code out to my editor, and run the NC file on my 750SS .. after a minute of running, error , y axes overtravel range... ok... so I look at the code and find this.
(REWIND: Tool is retracting due to rotary axes limits.)
N7475 Z0. F500.
N7480 G53 G0 Z0.
N7485 G53 G0 X-736.6 Y-203.2
N7490 C42.973
N7495 X-13.425 Y-31.231
N7500 Z0.
N7505 G1 Z-4.029 F250.
N7510 X-13.149 Y-31.31 B0.435 F752.01
N7515 X-12.867 Y-31.432
when posting I've tried to do G28 instad of G53 / no luck...
downloaded 2 other posts online and same problem, now I'm stuck.
meanwhile the toolpath is 3d Contour / with multi axis tilting enabled.
If anyone has any idea whats bothering me please do help.
Fusion
