LibertyMachine
in reply to: oharajesse
PM sent back to you. I'll copy here MOST of the text:
Couple of things:
1) Some of your issue was in your tool definition. If you are in fact using a lollipop tool, then the definition needs to be accurate. Your shaft diameter needs to be whatever the neck diameter of your tool is. I took a guess and defined it as .30" diameter. YMMV
2) I have things set very loose and coarse. Generation time is quite long and I'm an impatient sort. Once I find a path that works well, I'll crank it down to where I'll actually be cutting (tolerance and step over)
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
