LibertyMachine
in reply to: michael
Tighten up your toolpath tolerance. You have it set to .1mm which is quite loose. I typically run Adaptive around .0127mm tolerance with Smoothing set to .039mm
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
