- Mute
- Permalink
- Report
I'm trying to setup some extermal thread milling, I've selected the root of the thread as the geometry. But when I come to running the simulation, it's almost as if it's cutting half a pitch out, it's not cutting in exactly the same position as what's on the model. Is there any way to change this or is there a setting i'm not seeing?
Cheers
- Mute
- Permalink
- Report
The thread definition that is put in place by the modeling environment has little impact on the threadmilling operation in the CAM environment.
There is little need to define a modeled thread. Just model a shaft for OD, or a hole for ID. Select that and apply "Pitch Diameter Offset"
As an aside, modeling a thread does take a fair amount of computer resources. Unless you actually need it for assembly and simulation, I'd suggest going with a cosmetic thread (for display purposes) or just keep it simple shaft/thread
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
- Mute
- Permalink
- Report
Ah right I see! I'kk give that a go now and see what happens! Thanks for the reply!
- Mute
- Permalink
- Report
Yep that looks much better! Looked up what the dimensions are for m10x1, minor diameter being 8.773, difference from 10mm is 1.227mm, thread looks nice now!
Fusion
