11-12-2018
09:55 AM
- Mute
- Permalink
- Report
11-12-2018
09:55 AM
4th axis milling and trace function
I am trying to cut an access segment out of a conical object, and I am having to use both the contour and trace functions to get the cuts that I need. We tried to do a test run and found that after performing the contour around the cylindrical base it does not reset the A axis before performing the trace. Is there anyway to set Fusion to correct or reset the A axis before it starts the trace function?
11-12-2018
10:28 AM
- Mute
- Permalink
- Report
11-12-2018
10:28 AM
Could you share your file, or perhaps a sample file that demonstrates the issue?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply.
What machine and what post processor are you using?
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Fusion
