sstephe1622
360 Views, 4 Replies
3D Contour
I noticed with 3d contour that going up a cone the code is short X,Y moves not smooth circles.  Is it just the way Fusion360 generates the code or am I doing something wrong?
They've disabled smoothing on arcs for the time being. There was a gouging
issue that was being reported
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
3d Contour should still work if you enable Smoothing. Transitions between levels will always produce a lot of line movements though.
Each pair of circular moves is one level all the line moves are the transitions.
Mark
Mark Hughes
Owner, Hughes Tooling
Probably should have done a couple things different:
1) Not answer from my phone
2) Ask for the file so I can see exactly what the OP is talking about
@sstephe1622 could you share your file so we can see what you are dealing with?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
I turned smoothing on and that fixed my problem.  It's for a prototype and there is a NDA.
