Marco.Takx
Hi @Anonymous,
I see the issue you are talking about.
But in my opinion, you can plunge from outside into the depth you like to cut and start the operation.
I there a reasonable way you don't cut the outside geometry first and then plunge into depth for this operation.
Also, the Helix method is always Climp. I haven't seen a situation you like to want that!!
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
