11-06-2018
11:49 AM
- Mute
- Permalink
- Report
11-06-2018
11:49 AM
The Mach3 post only puts out multi-axis moves if it is set in the pre-post dialog.
You have to set the WCS in the in the setup otherwise you will have problems as you have seen.
When doing the cam in Fusion it does not matter one bit what way around the model is, you set the Z with the WCS in the setup, then if it is a multi-axis toolpath that is needed you set it in the toolpath only if it is different to the setup.
All this is in the support & learning at the top of the Fusion forum page.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Fusion
