It matter not which way your part is sitting in Fusion (Model or CAM workspace).
When you create a Setup, do not default to "Model Orientation". Rather, choose the "Select Z plane and X axis"
You then select the surface that is "normal" to the Z axis of your machine, and the edge that would be running along the "X" axis
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
