11-06-2018
06:57 AM
- Mute
- Permalink
- Report
11-06-2018
06:57 AM
Thank You!
The CAD model that I received had the Z axis "sideways" and I thought I just had to define the surface to machine by clicking on the desired "Z face". I eventually used the MOVE command to rotate Z in the desired direction and then there was no need to define the Z axis in the setup.
That is confusing though to me since it looks correct and I would expect it to work that way: Define what surface to machine. I am learning...
That brings up a related Question: If I need to machine a second surface, do I have to go back and rotate the Z axis again. Will the part not be also moved in sub-assemblies if I mess with the origin?
I need to watch your YouTube videos.
Fusion
