- Mute
- Permalink
- Report
I am trying to bore and do simple drilling operations on a part but can't generate the toolpaths. The part (and setup/operations) were taken from another file that worked. I can't figure out why the same operations on the same model part wont work in my new program. Thanks for the help.
- Mute
- Permalink
- Report
Tsk tsk. The issue lies in the model assembly itself, not the CAM.
Your parts are tipped .295 degrees, so CAM is not seeing that as a feature you can reach. Adjust your parts so they are sitting correctly ![]()
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
I'm having the same issue, but it happens when my model (for some reason ) loses its X-Y-Z orientation. Like, if I delete a reference line. On a toolpath that worked properly, I can reselect a X-Y reference, and it still won't regenerate. Is that common? Id hate to have to re-draw that whole thing again.
John
- Mute
- Permalink
- Report
John, this likely isn't the same issue as the op, so if you would, please start a new thread with the issue and attach a file that exhibits this behavior or perhaps a screencast
Seth Madore
Fusion
