@ProteumMachining wrote:
You could either select each corner as a point to drill through with your endmill as stated above or there was a custom API to add dogbone cutouts to flat pack items.
https://www.youtube.com/watch?v=ZCcD4MYGbzc
That's a pretty cool addon. I would add that it certainly has many applications aside from woodworking, too. I used to create tangent arcs slightly bigger than my nominal cutter in Mastercam when I needed an internal corner clearance for a punch or stripper plate, and those were more on the order of 3/4" diameter. I'll have to pick that up and see how it works.
Thanks for the heads up!
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
