youn8636
545 Views, 1 Reply
Return to Home Problem
Today I programmed a part in the HAAS SL-10 CNC Lathe with fusion 360 and had a return to home problems. After the first operation, the tool would move up in the X-axis and perform a tool change at that spot above the part. Then, it would rapid down at an angle that may have hit the part and broken my tool. I did not see an option in CAM to return to home after an op. I have never had this happen before and was wondering if an update changed this and if I have to add the return to home command manually.
Thank You,
Evan Young
