TecsolAus
in reply to: daniel_lyall
Re: CAM will not select ANY contours
Hello, You are correct.
After editing a similar model I was unable to select contours. I saved a
file to the local machine and pulled out the Ethernet cable.
After restarting Fusion offline I was able to select the contours. Plugging
back in to the network didn’t cause any issue.
I don’t think we can call this problem completely solved, but hopefully it’s
defined enough for Autodesk to get to work on it! And we have a work-around.
