233 Views, 1 Reply
Need help getting an insert to cut past an edge on my CNC lathe
I attached a screencast to help visualize this better. Basically I can't find a way to get the cutter to cut past the edge I've defined so it ends up leaving a lip on the part. You can see the material left over from the simulation when I zoom in.
Tags (1)
