- Mute
- Permalink
- Report
Yes that definitely seems like a bug. @jeff.pek can you take a look at the file in post #6.
@evanp4509U4JZ Don't think I'd ever set the boundary to tool outside like that as the toolpath can waterfall all around the edge. If I want the tool to go past the edge I'd create a helper surface and select in just the horizontal OP, see screencast. Fusion doesn't have an option for tangential extensions on 3d toolpaths so you need to create a surface. I'm using the new UI in the screencast, if you still use the old one pick the patch workspace from the workspace menu.
Mark
Mark Hughes
Owner, Hughes Tooling
Fusion
