TecsolAus
in reply to: Marco.Takx
Thanks for such a fast reply Marco!
I just tried exactly the same process that I’ve been doing all afternoon, but with the f3d file you tested. I can now select contours, holes etc in CAM mode! What is odd is that I tried doing a local f3d save and reopen earlier, and the problem was still there.
I have just opened the original model from the Autodesk server, and that now works as well. I wonder if closing and reopening Fusion made a difference? This happened once before and I gave up for the day, but when I came back to the job a few days later I was able to work on the toolpaths.
Cheers,
James
