JoeWight
in reply to: JoeWight
I messed around and found that it has something to do with the tool orientation or selection. When I select the general turning tool in the standard direction, it works fine.  I took the general turning tool and turned it 90 degrees.  I need to use wither this or a boring tool but it flat out won't accept the boring tool.
It also started complaining that I had 0 flutes with the boring tool which makes no sense cause there are no flutes on a turning tool.
