HughesTooling
in reply to: tomH9FZK
I was only showing how to use the taper option and left the pocketing\clearing to you. Here's a file with a couple of ideas, one just using 2d contour the other a 2d pocket and finish with a contour. If you want more options you'll need to make a 3d model and use 3d ops. One warning, I increased the length of your cutter.
Mark
Mark Hughes
Owner, Hughes Tooling
