tomH9FZK
in reply to: HughesTooling
Close, but I did not make myself clear.  This is a deep cut and even though I have a 4" end mill, I run out of flute about 2/3 of the way down.  See the screen shots below.  The tool path needs to clear out stock on the waste side of the cut to keep the shank from rubbing.  Will follow up with a ball nose spiral tool path to remove any steps.
