Just in case you want to know how to get the 2d tapered contour to work see the attached file. One problem you had was the model had a 5° taper but you set 15° in the contour op! To get a reliable toolpath with the taper option I've found you need to use "From Selected Contour" for the top and bottom height. I've selected the contour at the bottom of the model and set the top height to selected contour +1.5 and bottom to -.005.
Mark
Mark Hughes
Owner, Hughes Tooling
