daniel_lyall
in reply to: tomH9FZK
There are a few options 3D contour and ramp will work nicely cutting to just short of the bottom then coming back with a 2D contour to finish so you still have tabs, or not.
You can use the heights to control where the toolpath stops and starts if you wont to go with the option of finishing with a 2D contour.
You will need to use a ball noise end mill to get a good clean surfaces a flat end mill will leave ridges.
Example attached
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
