08-25-2018
01:13 AM
- Mute
- Permalink
- Report
08-25-2018
01:13 AM
See attached file. All I needed to change was unselect stock contours and then select the outer circle as a pocket selection, make sure the 2 pocket profiles point in opposite directions to make the pocket between the 2 curves. Also had to change the minimum ramp diameter to 0.5mm.
I got a warning your file was created with an older version of Fusion so you'll need to update to open the file.
Mark
Mark Hughes
Owner, Hughes Tooling
Fusion
