638 Views, 1 Reply
CAM Template editing and updating toolpaths
Hello!  I am toolpathing 14 sheets of material that will all have the same operations done on each of them.  I created a template with the operations and toolpaths I will be using in order to have a starting place for each sheet.  I would love to be able to edit the template and have it update the toolpaths on all of the sheets that I had previously used the template to create.  For example, if I originally set the template to cut at 100 in/min and then decided I want it to go at 150in/min... If I change it to cut at 150in/min on sheet 1 and overwrite my old template, all of the toolpaths that I used the old template on (the 13 other sheets) stay the same and I would have to change them all individually.
Is there a way to change one factor of the operation and have it update the toolpathing for all of the sheets at once?
Thanks!
