07-27-2018
09:16 AM
- Mute
- Permalink
- Report
07-27-2018
09:16 AM
Unless there is a G49 command somewhere in the code which is the command that will cancel a G43/G44 Tool Length Offset or something specific to the HAAS control that would cancel the G43/G44 then that is what I would consider normal, if there has not been a change to a different tool in between the operations using the same tool then the G43 offset "stands" until it is cancelled either by a change to a different tool or a G49 command is posted.
Nothing to worry about IMHO, hope that helps
Regards
Rob
Fusion
