tomGKJVK
668 Views, 4 Replies
CAM Post Does Not Reset G43 For a Repeat Tool
I just noticed this problem a couple weeks ago.  When I'm using the same tool twice in a row for different operations, it does not set G43 the second/third/etc times.   I'm using G28 and M01 at the end of each operation, which is clearing the tool offset.   So, it needs to put G43 at the beginning of the next op even though it's the same tool.  Safe Start All Operations is checked.
I'm using the Haas (pre-ngc) Post.
