daniel_lyall
in reply to: kevin.ifix
It could be anything doing it from the rubbish tool zero script in that screen set to mach3 just being a ****.
If you are doing manual tool changes all you need to do is home the machine set your work zero to a spot on the material, vices or machine bed.
Then when the next tool change comes up change tool  zero the tool to the same spot move it so it is in a safe spot and hit cycle start.
This is all you need to do and make sure you have stop spindle wait for cycle start set in general config set.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
