07-20-2018
11:23 PM
- Mute
- Permalink
- Report
07-20-2018
11:23 PM
Extend the handle a little in your model, because I assume your cutting it off anyway. And create a boundary sketch to contain your 3D path. Machine one side, then rotate the 4th axis and machine the second side.
Fusion 360 only supports cylinder wrapped 2D paths at this time.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-7FF25192-AED7-4230-92DC-E22ADF15D498
https://www.youtube.com/watch?v=kcc-vxDQD4Q
This part doesn't really require a 4th axis to machine but I assume your just using this model to learn. In reality this part could be milled 2D. ![]()
I attached the model that mills one side and then flips the part 180 degrees and does the second side.
Fusion
