magpiemachining
518 Views, 8 Replies
lift height and pocket solution needed
Morning Folks, The lift height is a problem here and i am unable to produce the code without him lifting the tool to re position whether in rapid or feed. Is there any way to keep the tool on the surface the entire time? Tool 30 pocket path travels through the contour selection.(see screen shot) any idea why? There are holes in this plate. (there is another body to select from)I filled them in to try to get the path correct. I had no success creating the path from the geometry with the holes present.
